piston question. PRetty sure it is not good?
the trail rider
on my kdx 220 which has not been rebuilt, from the intake side behind the reeds, the piston has a hole a decent sized hole. probably as big as the wrist pin hole or maybe a little bigger. Is that supposed to be there. I am pretty sure there is only supposed to be a tiny hole to let the crankcase breath right, this thing is big compared to that. is it chipped or broken. I am pretty sure it is but just wondering guys, that is probably why I am having my low end problems. and also(if it is broken) IS there a way to fish it out of my bottom end with a BIG Magnet. thanks, The Trail rider.
Pull the motor, pull the topend and turn it upside down!
- Colorado Mike
Post a pic. Or terminate questions with a question mark. The stock piston has an oval hole , bigger than the wrist pin holes on the intake side. It also has a cut out in the skirt below that. Care to guess how the mixture gets down into the crankcase?
the trail rider
so your saying it's not good. oh boy. I hope to god that it didn't scratch up the cylinder walls.correct me if i am wrong, that hole is not supposed to be there right. It is supposed to be a tiny little hole, right. oh great. probably why it was louder last time I rode it to. I put the stock pipe on to see if it was the pipe and it was still boggy with the vfIII still in. tell me if my speculations are correct.
get a lift, fat chicks can't jump!
when in doubt gas it!
the trail rider
- Colorado Mike
The arrow points to the exhaust port. The Exhaust side of the piston has little tiny lubrication holes, 4 of them in fact. BTW, the stock piston on a 220 has been known to break ya know. Some don't maybe you'll be lucky. The stock 200 pistons seem to be fine.
the trail rider
- Colorado Mike
the trail rider
I am sure my bike needs a rebuild any way. that could be why it is running so bad, loss of compression or something, maybe to much ring blowby. I was told to get the desert for the 220 and so far I am not very impressed at how it took away almost all of my low end snap, and for the most part power in the lower rpms. I love the top end it gives me, but I do not like screaming it out all the time, it seemed like if I was gonna ride in the higher gears I had to haul ass to stay with some power
. the one thing I did like about the stock pipe was that it had a ton of low end
. Maybe I should have gotten the woods pipe.
marco220
I have the stock piston from my '02 220 and I measured the hole on the intake side....
Approx 13/16 wide x 5/8 tall (oval shape)
The exhaust side has four 1/8 holes.
I've seen the carnage of a broken skirt first hand... dump the stocker and drop in a Weisco. Better safe than sorry!
2002 KDX 220
RB'd Carb and Head
I don't crash often... but when I do, I'm going for style points!
RB'd Carb and Head
Matt-itude
re: 'Aluminum ain't magnetic.'
Ha!! Beat me to it....
I missed this:
1. The stock piston has an oval hole , bigger than the wrist pin
Then,
2. so your saying it's not good
I don't know about good, but it IS normal. Marco's post verified that..right?
Crud (including dropped clips and piston frags) can be removed from a crankcase a number of ways.
1. Put a gob (technical measure) of grease on the counterweights of the crank, rotate by hand to 'scoop' up the junk.
2. Run a clean/oiled rag through the case..chase it with the counterweight. Use a rag large enough to keep hold of one end in case it gets bound up on something.
3. Wash the case out with a light oil. Something magical like Marvel Mystery oil or some such. Diesel would probably work OK, too.
If your 220 doesn't have an acceptable lower-throttle response..even with a -30 pipe, it is very likely a jetting problem (other standard 'problems' like KIPS and no-compression being OK).
All of that is on another thread, ain't it?
I missed this:
Then,
