Powervalve subvalves
tucker
Country: New Zealand
Post by tucker »
Hi all
I just rebuilt my top end on my KDX.
I cleaned and serviced my powervalve.
The first time I put everything back together I tripled checked the timing of the PV was correct and everything lined up. I then looked through the exhaust port and was turning the main shaft. Everything closed as it should. However, on opening, the left subvalve (viewed right through the exhaust port) seemed like it was partially open as I could still see part of it as opposed to the right subvalve which looked like it was completely flapped back (open).
I though it was odd, so I took it all apart again and reinstalled it. Triple checked. Same thing, so I just put it down do the design.
Is this something you have come across? is it something to do with the design and the interaction with the resonator?
kdxdazz
Country: thailand
Been thanked: 4 times
Re: Powervalve subvalves
Post by kdxdazz »
I had that on my bike too and same thing I pulled it apart then reassembled, decided it must have just been a factory thing.
bikeman2502001
Post by bikeman2502001 »
Yes mine also i dont use the marks at all I only go by their action i have no problems that way
