New to the site from central NY
RPM
New to the site and to the kdx world. Purchased a 1995 kdx200
With what I was told to be a 2007 kx 250 triple tree and forks. They seized up first ride unfortunately.
- E9BC9A52-00E9-4B1A-BBEC-71B5AA49C23A.jpeg (185.36 KiB) Viewed 4144 times
- ABAD48B3-8616-42B7-BF62-5385DEA47538.jpeg (3.56 MiB) Viewed 4144 times
- Has thanked: 191 times
Re: New to the site from central NY
Welcome to kdxrider.net.
- Been thanked: 10 times
Welcome to the forums and congrats on the bike. The forks seized up or the bike? Try opening the fork cap bleed screws and see if a bunch of air rushes out. Post a couple pics of the forks/triple and we can help diagnose what's going on.
RPM
- 0AA9B899-7952-4FD8-96B2-A7762C345DB4.jpeg (2.91 MiB) Viewed 4131 times
- 7B98D2F8-821F-4192-BA09-044CC0958623.jpeg (1.95 MiB) Viewed 4131 times
- B4CC0A47-44D4-4D39-A22F-909B1A9B24A2.jpeg (2.97 MiB) Viewed 4131 times
The forks may have been longer, giving it that chopper feel.
If you have more pics of the forks, I may be of help. I have a set of 2007 KX250 forks buried in a shed, unable to access them, but I am familiar with the looks. I have a 2005 KX250. Those forks are very similar. 2007 did not come with fork guard guides.
RPM
When I get them back from the shop I can get closer pictures. When I measure the factory kdx forks that were spares the corrosion shows where they were originally mounted and the distance to the axle. That moves the kx forks up about 5/8” so when they get finished up I’m hoping moving them up that 5/8” will set the rake correctly.
- 936B6DCC-4E6B-4562-B0BB-D9A8884F833C.jpeg (1.91 MiB) Viewed 4126 times
- C808B826-9556-4323-9ED7-8E375D266C03.jpeg (2.75 MiB) Viewed 4126 times
- 945D98A9-AC22-4A25-AF2D-E3CBE41881C7.jpeg (4.74 MiB) Viewed 4126 times
- 063B3FED-68DA-458B-8CDF-7DD4DE888897.jpeg (3.24 MiB) Viewed 4126 times
Looks like 2007 forks to me.
Cool pipe guard.
Pull the forks up in the clamps a bit to try again on getting rid of the chopper feel. A few have had their forks lowered internally, but most just pull 'em up.
Cool pipe guard.
RPM
Thanks kdx garage. It was not a cheap bike by any means. It came with a motorcycle title as well. All and all I think it was a good purchase. It seems to be in pretty good shape
It looks like you got a few nice aftermarket pieces (I see the pipe guard, Devol rad guards, bark busters, a WER steering stabilizer, I have the same one and love it, seat has been recovered, rear shcock looks like it may have been worked on at some point, looks like maybe a Clarke oversize tank. Just looks like it didn't receive a lot of routine preventative maintenance.
In the pics above the forks are definitely sitting too low in the triple clamps, which is why it felt chopper-ish.
RPM
I found some bushing missing from the front caliper. Just ordered them. And the crankcase breather wasn’t there. I think your right about maintenance. Bearings and bushings seemed good though. Chain is getting a little loose and topped out. I’m gonna change oil coolant and keep looking for missing parts or anything out of the blue. I only got to ride It the one time before sending out forks. I believe I would like to change up sprockets when I get a new chain. I don’t need speed at all.
