KX Fork swap triple clamp height
ccain85
Post by ccain85 »
Hey guys, I just finished completing my fork swap and was wondering how far up in the triple clamps do you have the forks set at?
Re: KX Fork swap triple clamp height
‘01 KX forks. I like mine @ 17mm. I did have to put short bar risers on to get room, but the adapters to run fatter bars took care of this.
Been thanked: 55 times
I'm running stock length '06 KX250F Showa forks. I 'm at 20mm above the clamp. That's measured from the clamp to the line were the fork cap screws on. I also have higher than stock handlebar clamps, but not by much, as I had a Scotts damper on their at one time.
Has thanked: 190 times
ccain85, anyone else in the future...the trick is to measure how high the bike was with the KDX forks, then replicate that.
Maybe someone can measure a stock KDX for you. Not tubeheight, but as in, from the ground, up to the head tube or something like that.
KDXGarage wrote: 10:51 am Feb 26 2020 ccain85, anyone else in the future...the trick is to measure how high the bike was with the KDX forks, then replicate that.
Yeah, that info would be ideal.
That said, no one can really use my info at all since I don't have the factory rear shock.
TwistedRoot
Post by TwistedRoot »
doakley wrote: 08:17 pm Feb 25 2020 ‘01 KX forks. I like mine @ 17mm. I did have to put short bar risers on to get room, but the adapters to run fatter bars took care of this.
I was running them at 18mm but still experimenting. I have the ProTaper mounts and they do rise about 1". I would like to replace the aluminum cones with rubber. I know this was discussed somewhere..
2002 KDX 200
2003 KDX 220
javjacob
Post by javjacob »
I had my 01 KX250 forks lowered 3/4"
I also run a -1.125" Kouba link so I still had room to play with. A safe bet would be to have them lowered 1/2"
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
