Shock crossover
EzLivn
Shock crossover
Can anyone tell me if the shock used on 96-06 kdx’s was used on any other dirt cycle? I have yet to find a parts fiche with the o rings in the top deepening adjuster.
EzLivn
Re: Shock crossover
dampening!EzLivn wrote: 03:13 pm Feb 11 2020 Can anyone tell me if the shock used on 96-06 kdx’s was used on any other dirt cycle? I have yet to find a parts fiche with the o rings in the top deepening adjuster.
- Been thanked: 10 times
Re: Shock crossover
KDXGarage will likely have the answer as he has all the secret Kawi books laying around his shop seemingly lol. I do know that most of the parts on the 200/220 shock are the same as those on the E200, 91-94 KDX250, 94-96 and 06-07 KLX250R/S, the 97-07 KLX300, 93-96 KLX650R and the 87-200 KX125/250/500. Not all those share the same shock length, but you could probably get pretty close. If you have the orings out you can measure them and order through a number of sources online (McMaster-Carr, etc).
- Has thanked: 159 times
- Been thanked: 39 times
Re: Shock crossover
Just measure and buy new viton.
Any reason you took the compression adjuster out? Were you changing oil?
EzLivn
Re: Shock crossover
Thanks for the replies. Even appreciate the help from grammarguy. Yes I am doing an oil change and replacing leaky seal.
Re: Shock crossover
OK. Sounds good.
