Oil leak between stock pipe and silencer
Mjkdx
Post by Mjkdx »
Why do I have a oil leak between stock pipe and stock silencer put new rubber at the connection
Re: Oil leak between stock pipe and silencer
Post by kdxsully »
Running rich maybe?
Running rich...spooge. Proper jetting can eliminate most all of it.
Has thanked: 83 times
Been thanked: 20 times
Welcome to kdxrider.
Have you seen in the service manual about blowing out the extra oil? (cleaning)
Also, if the jetting is off, there will be a good bit of unburned oil in there. Clean it all out and get the jetting / mechanical operation correct to help it out.
