Clutch
Aircooled22
Clutch
Hi guys, I have taken my clutch cover off to measure the wear on my friction plates. I thought I had put the clutch back together exactly like I took it apart, but when I put the clutch cover back on, the clutch release rod on the clutch cover won't rotate!
I have a service manual, and put the clutch back together like it says. Can anyone help?
Re: Clutch
Probably some of the better mechanics will respond but immediate question is did you rotate the lever to the rear before putting the cover back on?
Aircooled22
Aircooled22
Aircooled22
Re: Clutch
Yeah, just rotate the lever to the rear about 90* before slipping the cover in place. If that doesn't work, then most likely you missed something so go back and review the manual.
Aircooled22
Re: Clutch
the cover will go on the bike but when i rotate it forward to attach the cable, it hits the clutch pusher
Aircooled22
- Kdxfan4130
- Country: Usa
Re: Clutch
Sounds like you have something assembled wrong. Go back to the manual would be my suggestion.
Aircooled22
Re: Clutch
I think i got it figured out, i had a few washers in the wrong place, and when i put them where the manual said, it all fit together. Thanks for the help and sorry to waste your time
Re: Clutch
Never a waste of time to try and help. In my recent overhaul I had to split the cases a second time just to check I hadn’t done something wrong. Can be frustrating.
Good luck with the bike.
- Has thanked: 110 times
- Been thanked: 31 times
Re: Clutch
No waste, just a problem solved. Congratulations.
