Desert Pipe = Sparkplug fouling
Hendrikder
Country: South Africa
Post by Hendrikder »
Good Day everyone
I would just like to know if a desert pipe (FMF Gnarly) could cause my spark plug to foul when I am riding technical terain at low throttle for a while?
I think my jetting is good for my current weather and altitude.
Thanks for the help
Ride or Die
2005 KDX 200
Has thanked: 50 times
Been thanked: 17 times
Re: Desert Pipe = Sparkplug fouling
If you are riding in real slow terrain with low throttle situations, consider a one step hotter spark plug. Also "clear it out" on occasion.
I would not be looking to blame the pipe at this point.
Has thanked: 10 times
Been thanked: 12 times
I run a desert pipe and have done quite a bit of nasty hike-a-bike stuff and never fouled a plug.
SS109, which heat range plug do you run??
tman
Post by tman »
Jetting is wrong.
Post by kdxsully »
KDXGarage wrote: 03:00 pm Jun 10 2019 If you are riding in real slow terrain with low throttle situations, consider a one step hotter spark plug. Also "clear it out" on occasion.
+1
KDXGarage wrote: 08:47 am Jun 11 2019 SS109, which heat range plug do you run??
A standard NGK BR8ES.
Yup, you have to turn the screw & clean the engine out every so often. When it get "blubbery" clean it out.
Hendrikder
Thank You very much for the help
I will try a hotter spark plug then, I am running the standard BR8ES I will then move to a 9.
Thanks
Ride or Die
2005 KDX 200
A hotter plug in an NGK would be a BR7ES. Smaller # = hotter plug/larger # = colder plug
For the record, my bike never loads up/gets blubbery and doesn't need to be blown out when riding. I would bet you need to tune your jetting. Have you followed the jetting guide? Have you done any plug chops to confirm your jetting?
