Installing side plates.
Xero0620
This may sound dumb but I’m installing some side plates without a previous reference on the bolts needed to install them. I see that one side has a larger hole at the top than the other. Does anyone have an install reference or pictures I can look at to see what is used for bolts and washers. Looks like the one may need some sort of rubber gromet. Thanks in advance
- Has thanked: 191 times
Re: Installing side plates.
Welcome to kdxrider.net.
Here's a pic from Partzilla, where I usually buy OEM parts.
Xero0620
You're welcome.
If you look through their diagrams, you can click on the part number, and it will show the models that came with that exact part number.
It is very helpful when shopping for used parts.
