SWINGARM ???
beeds3000
SWINGARM ???
I own a 1997 KDX 200, I want to eliminate the Kickstand welded mount and it is dented, does anyone know if a KX 125 or 250 swingarm will fit??? if so which one ???
Geoff T. Biderman
- bradf
KX swingarms won't easily fit. The motor mount bolt area (the hole in the rear of the motor that the swingarm bolt passes through) is wider on a KDX than on a KX. The KDX motor would have to be machined down to get the KX swingarm to fit. It has been done to put a KX motor in a KX frame. It would be much easier just to grind off the welded tab. It can be done so that you would never know it had been there.
- m0rie
Completely off-topic, but I love your avatar bradf! Stewy is awesome by himself...Stewy with dancing girls...Wow!
