Rear tire locks up
Thadius
Rear tire locks up
2000 kx125 set up for a while put a new top end and installed a new crank put bike back together, rode bike shifts great no problems but one you cut bike off and start to push it into shop the rear wheel locks up it is in neutral made sure of that, you can roll the bike backwards no problem and tire will spin freely on the stand it has got me scratching my head.
- Been thanked: 10 times
Re: Rear tire locks up
On a stand in neutral the rear tire spins freely in both directions? With no resistance or odd noises? But take it off the stand and it doesn't? Your chain is properly adjusted? From the description it doesn't sound plausible, maybe a video would help visualize.
Thadius
Yes chain is adjusted properly and no noises on stand and spins freely but one you hit the ground and try to push it it will have a fint clicking noise the just lock up like you put it in frst gear but you can push it backwards and it's still free
- ss109
- Has thanked: 31 times
- Been thanked: 49 times
Rear tire locks up
Only thing I can think off means opening it back up. I would first pull the right side cover and have someone roll it forward while you look to see if something is jamming it up. I would pay close attention to the kickstart gear. If you can't find anything in there causing the problem then it's probably inside the cases.
Would love to see a video of the problem.
