TT question
- Ryan
TT question
Can i get the bottom bearing off of the kx triple tree myself or do i need a press or something??
2001 kdx220
1987 honda xl250
1987 honda xl250
Gee... didn't you just ask the same question in another post?
- m0rie
- skipro3
- skipro3
First time I used a prybar and a hammer.
Since then, I just use a cold chisel and cut it off.
To install a new bearing, I use a piece of pipe, an old bearing as a buffer, and press it on, or tap the pipe with a hammer.
The bearing will come off when the stem is pressed out.
- skipro3
I misunderstood. I thought you where just looking to replace a bearing, not do a stem swap as well.
Since the stem HAS to be pressed on and off, have the bearing done at the same time. A simple 20 ton hydraulic press will do the trick and your NAPA dealer may well have it. My local NAPA dealer does and he set up my KX stem and bearing when I upgraded to a TAG TT. Good Luck!!!
****EDIT****
Have them pack the bearing while it's off as well. It's much easier then. Also, have them show you how to hand pack a bearing. It's a good thing to know.
****EDIT****
- skipro3
Not that I know of. I didn't use them for my KDX conversion. I used them for my KX250. I got a TAG upper and lower triple clamp and needed a bearing. I brought in my lower clamp/stem piece to show them what the bearing fit and they offered to press the new bearing on. They even gave me the grease to pack it. I had to pack it myself, but it's not hard if you know how.
- Colorado Mike
- KDX220PHIL
Try saying it right
- knurl, (nûrl). not (k-nurk-kling)
knurled, knurling. do not pronounce the k's.
"Do you have a lathe and a straight line pattern knurling tool?" Maybe that will help when you start calling other places Ryan, you do not want the diagonal or diamond pattern.
Try a fabrication shop, someone who operated a lathe at least 50% of his time will be far more experienced than someone who uses one a few times a week.
Like Mike said , check the yellow pages, they will be there.
