48 T sprocket, chain length.
pumpguy
Post by pumpguy »
I have a spare rear wheel for my H series KDX 200, and am thinking of fitting a 48 tooth sprocket. The CS sprocket is standard 13 tooth and the chain is standard 108 links.
Using an online chain length calculator, it says the center distance using the 108 link chain will decrease by .172", or a little less than 3/16", compared to the standard 47 tooth sprocket.
I could measure the amount of adjustment I have left, but the bike is not where I can get to it right now.
Does anyone know from their personal experience if I can use a 48 tooth sprocket with the standard 108 link chain and 13 T CS?
Has thanked: 10 times
Been thanked: 12 times
Hmm, could be close to being a little tight but would probably be ok. I'm running 13/48 with a 110 link chain. Snail adjuster when new was at 3 and was just recently adjusted to 3.5 after 6 years. I do tend to run my chains a little on the loose side though.
pumpguy
Post by pumpguy »
With the snails at 3, you have quite a bit of rear adjustment left. Combined that with a 110 link chain, this doesn't sound too encouraging for what I was hoping to do. My 108 link O ring chain is in very good condition, and I really don't want to buy a longer one just to go up one tooth on the rear sprocket.
Maybe I can find an extra link set and another master link to come up with the needed extra length.
Thanks for your reply. I really appreciate it.
How much adjustment do you have with the 13/47 and 108 link chain?
pumpguy
Post by pumpguy »
My snails are at 5.
You think the adjustment wouldn't be enough? I think it would be real close but just might work.
pumpguy
Post by pumpguy »
On another site, RMATV I think, there is a post saying a 48 T sprocket will work with standard 108 link chain and 13 T CS sprocket.
Guess I will just have to put the sprocket on and see for myself.
Thanks again.
Your welcome! Hope it works. Please update us on how it turns out.
ohgood
Post by ohgood »
pumpguy wrote:I have a spare rear wheel for my H series KDX 200, and am thinking of fitting a 48 tooth sprocket. The CS sprocket is standard 13 tooth and the chain is standard 108 links.
I have 15/48 on my h , you'll be fine.
ohgood
Post by ohgood »
SS109 wrote:How much adjustment do you have with the 13/47 and 108 link chain?
15-48 is set on about position 2 , chain has very little wear on it, new sprockets
With a link 108 chain?
pumpguy
Post by pumpguy »
Good news!
With a new 48 T rear sprocket, the fit is just fine. Snails are now set at 3. No other changes were made.
Thanks again to all who replied. Hope this helps others considering this change.
Vossman
Re: 48 T sprocket, chain length.
Post by Vossman »
Have you guys found any issues with the chain guide when going to a bigger sprocket?
