KIPS timing 200C
RandyNJ
KIPS timing 200C
I recently purchased an 87 KDX200c with a tired motor. Sent the motor to a local shop where a friend with 40+ years of experience to go through the engine. Sent the jug out for replating, mew piston, seals, etc... Gave him the factory shop manual as well. According to him, using instructions from the manual, the kips valves are closing as the rod pulls out, and wide open with the rod in, which is the opposite of every other motor he's assembled in the past. Does the rod work opposite in this motor, or are the instructions for assembly backwards?
Thanks in advance
Thanks in advance
david
- Country: UNITED STATES
Re: KIPS timing 200C
Could he have the valves switched, right vs left?
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
RandyNJ
I thought of that too, according to the manual, number of grooves in top of valves, he has it correct
david
I'm not familiar with the C series, but the factory manuals have been wrong before.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
- Has thanked: 48 times
- Been thanked: 15 times
The first version of the 1995 manual was wrong.
I am only sure of one thing. With only two valves, no flapper and only one rod, it won't take long to figure out.
Welcome to kdxrider.net.
AND Congrats on the '87!
KDX Geoff
KIPS timing 200C
I found that too.
Using the manual and checking the operation, they seemed arse about and l spent a lot of time trying to work out how l was doing it wrong.
In the end l set them up visually so they worked correctly because the workshop manual setup didn't seen right.
pkenney
- Been thanked: 2 times
Question: Is the KIPS system designed for increased low end or top end power?
The passages should open as the revs rise correct?
With the shaft extended the alignment dots should be facing the front of the cylinder.
With the shaft all the way in the dots are at 9:00 looking from the intake side.
This is the way mine are set...but then again it does not have much low end power so maybe I have it wrong.
Not trying to confuse the OP but my setup does seem to contradict the manual.
david
The valves open above 6000rpm and give you a boost of top end power. If they don't open, the power just kind of falls off at that 6000.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
pkenney
Thanks for the confirmation.
I'm curious what the affect would be if they were set the way the manual says.
The ports would be open at low revs and close at high revs - more torque?
If I had some spare head gaskets I might try this.
I'm always looking for more torque and would trade some top end.
david
If your valves were working opposite of the way they were designed, it would kill the bottom and the top end power. Motor would be a total turd.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
