Stiff Clutch
bergilong
Stiff Clutch
I replaced the clutch plates, springs(heavy duty), and cable on my KDX200. The clutch pull was insanely hard. I had to use two hands to pull the clutch in. I put the old clutch springs back in and it helped a lot, but the clutch pull is still harder than normal. Any ideas?
david
- Country: UNITED STATES
Re: Stiff Clutch
Cable routing? Is the cable itself binding or kinked?
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Stiff Clutch
Cable routing would be first check. I also lube new cables to make sure they are lubed well. Was your clutch basket really notched?
bergilong
Stiff Clutch
My clutch basket was really notched, but I filed it down. I'll check cable routing.SS109 wrote:Cable routing would be first check. I also lube new cables to make sure they are lubed well. Was your clutch basket really notched?
- 6 Riders
Re: Stiff Clutch
Check to make sure all your bolts are torked to spec. You can get a hard pull If the bolt holding the clutch to the shaft is loose at all.
