Howdy
mskinner
Country: usa
Howdy
Post by mskinner »
Hello From Seguin Texas.
I just bought a KDX220. My question is...Is the stock needle adjustable?
Thanks
Matt
Has thanked: 116 times
Been thanked: 31 times
Re: Howdy
Welcome to kdxrider. :partyman:
The stock needle has five clip positions on the KDX220R.
mskinner
Country: usa
Re: Howdy
Post by mskinner »
Thanks Jason, so is there a tutorial about how to access that little bugger? I have taken the top off and looked at the area where the spring /throttle cable go down into where the needle sits, But I cant figure out how to access the needle. Help!!!
Thanks :grin:
Tyl3r
Re: Howdy
Post by Tyl3r »
Once you pull back the spring and wiggle the cable out of the slide, you take a socket (6 or 8 mm I believe), and loosen the hex that has the groove in it for the cable to run down... kind of hard to explain, but once you get the cable out of the way, you can only see 1 hex inside of the slide. Just hold the slide in your hands when doing this, I wouldn't try clamping it or anything in fear of damaging it.
mskinner
Country: usa
Re: Howdy
Post by mskinner »
10-4
I'll give it a try.
Thanks Fella's
Jim B
Re: Howdy
Post by Jim B »
Tyl3r wrote:Once you pull back the spring and wiggle the cable out of the slide, you take a socket (6 or 8 mm I believe), and loosen the hex that has the groove in it for the cable to run down...
6mm. Don't tighten too much when you reinstall, you'll crush it.
Re: Howdy
Yes, 6 mm
mskinner
Country: usa
Re: Howdy
Post by mskinner »
Ok,
After fiddling with it, I find that the bike runs quite well with the needle clip in the first position.(leanest setting).
Is there any danger of leaving it there(possible damage) and does that indicate that my jetting is still too rich and I should go back to the 2 or 3 position and go leaner with a 38. I'm at 40 now.
Thanks
mskinner
Country: usa
Re: Howdy
Post by mskinner »
BTW I'm in Texas 700' and warm humid weather.
barefootbob
Country: usa
Re: Howdy
Post by barefootbob »
Hi mskinner
Jetting can get a little involved, not sure if you can find your answer on the procedure here but plenty of info on the net, I'll bet you can even find a video on YouTube.
Never yield the right of way
mskinner
Country: usa
Re: Howdy
Post by mskinner »
I removed the airbox lid and opened up the breathing with a new filter, and that made all the difference.
YEEEHAWWW.
