First let me tell you that this forum is already very helpfull in a lot of way..
English is not my first language so bear with me if my use of word are not always correct
Here's my problem..
I just bought a 2000 KDX 220 yesterday.
I have made like 3 run with it totaling maybe 2hour of riding. Everything from clutch to gear shifting to braking was spot on.. Then.. When loading the bike in
my friend pickup it fell in the grass on it's left side.. Not a big deal i tought so picked it right up
and loaded it in the pickup.
Next Ride.. First Gear did not enter right on, had to stump on it maybe 3 time.. then it was kind of ok.. Second gear third fourth fifth sixth .. Then i had some difficulty downshifting it trough to first.. So i turned around and get myself back home(Again with some hard shifting)
So after some reading i started to open the right side cover to check if the neutral spring was ok.. But not having an impact at hand i am not able to unscrew the 21mm Bolt in the center of the clutch? but opening it, still gave me a look at something i wanted you guys to look at.
Ahhhhh i dont know how to insert an image of it!!
