Hybrid ignition
james85kdx80
Hybrid ignition
Picked up an 85 kdx 80 missing stator, rotor, and cover. Does anyone know difference in kx vs kdx parts? Bigger kdx has lights so I could understand difference but 80 has no lights or battery. Ignitor box, coil, and engine cover same for both. I see crankshaft and crankcase are different part numbers so is mounting or timing different or can I use kx parts as long as I keep stator and rotor matched?
- Has thanked: 160 times
- Been thanked: 40 times
Re: Hybrid ignition
I am not sure on that, but if you look up the part numbers for the KDX, you may find several years had the same part numbers and can find used parts on eBay.
james85kdx80
Re: Hybrid ignition
aahhh found it. kdx cdi is part #21119-1115 and kx is #21119-1155. looked same at quick glance. kdx has 2 wire plug kx has 3.
james85kdx80
Re: Hybrid ignition
Got parts ordered off eBay. Anyone can send me a link or pics on how to time it?
