KDX Plastics ?
beeds3000
KDX Plastics ?
I have a 97 KDX 200 will the KX plastics fit on it to eliminate the lights ???
I have seen guys with different style plastics on their KDX does anybody know of a websight to buy these ???
Geoff T. Biderman
As far as I know... the style is the same... just the graphics are different. You can adapt a numberplate on the stock frontend if that's what your looking to do.
The shroud, and side numberplates have to remain OEM KDX or aftermarket for the KDX ....
Generally that's what adapt means. There is not a ready made plate to replace it exactly.
It sounds like you really want a KX.....
- m0rie
If the lighting coil is bad you could send it out to be rewound. Ricky Stator can rewind it for $40. Having a rewound coil makes a little more pull down low as well.
beeds3000
- m0rie
- m0rie
If you have a service manual there is a procedure to test the lighting system. If you don't have a manual you should pick one up. Its got lots of useful info for maintaining your bike.
