Compression test pricing
NV Rider
Post by NV Rider »
In the US, how much should I expect to pay for a compression test on an air cooled engine? (1981 KDX250)
Also. I see one can buy testers for $30 or even less. Worth the trouble?
1981 KDX 250. Purchased February 2017. A work in progress
2010 Cervelo S1. I know, no engine, but it is a bike;-)
s10gto
Re: Compression test pricing
Post by s10gto »
I would say a 1/2 to one hour shop labor. It would be worth getting a compression gauge. Very easy to do.
Best would be to get a leak down tester. You need a compressor for it to work but it tells you much more about the engines condition.
Check you tube. Many vids on them.
Been thanked: 2 times
Post by John_S »
I would agree with s10 that you should have both these tools. I bought my compression tester from advanced auto for about $30 and I spent another $25-$30 making a leak down tester that uses a squeeze bulb with air release dial from an old blood pressure cuff that was up in the closet lol. I wouldn't use a compressor to fill it even if it had a shrader though. A bike pump would be fine for filling the needed 6 psi. I'd be afraid a compressor would quickly blast too much air in and blow a seal. Spend the money the tools that you can keep rather than having a shop do it.
NVrider, I just made a post showing the leak down tester I made.
