Broken SHAFT-COMP, GOVERNOR 13234-1101
oilburner00
Well...I was almost home free. I was finishing up my top end rebuild on my 2000 KDX220 and I torqued the nut on the shaft (SHAFT-COMP, GOVERNOR 13234-1101) too hard. Broke the end of it right off. And this is after I read all the warnings and I WAS supporting it. And also going the right way.
So now, $86 later, I have another shaft on the way. What all do I need to do to replace this part? I'm afraid I will have to split the bottom end open? I have the Cyclopedia online manual but did not see how to replace this part. Unless I just missed it. Any guidance would be greatly appreciated. Thanks in advance.
- Has thanked: 193 times
- Been thanked: 49 times
Re: Broken SHAFT-COMP, GOVERNOR 13234-1101
right side engine cover
How many inch-pounds did your torque wrench show??
oilburner00
Just take that off and I'll be able to access it?
And too much. That's how much I torqued it
- Been thanked: 10 times
Yes, and you will be able to inspect the pin at the bottom to make sure it didn't get tweaked as well. Yeah, make sure you're using an IN-LB, 74 in-lb is not a lot of force.
Did you use a torque wrench? I am thinking you cranked on it, not "torqued" it.
oilburner00
I'm going to be honest...I wasn't using a torque wrench and I knew I should've been while I was doing
Is the engine cover easy to take off? My bike is at a different location right now so I can't take a look at it. And I'm assuming there is a gasket for the cover that should be replaced also?
Thanks guys, this is the first time I've ever been into an engine so I appreciate the help.
Yes, there is a gasket. The old one may well break when you take it off. You will need to drain the coolant beforehand also.
oilburner00
Someone help me out.
drain transmission oil
drain coolant
remove kickstarter
remove inner / outer clutch cover combo
new gasket between inner clutch cover and right crankcase half
new transmission oil
new coolant
Again, someone help me out on that
drain coolant
remove kickstarter
new coolant
- 6 Riders
Remove water pump hose?
Remove brake lever and/or the spring?
KOOM BY YAH
KOOM BY YAH
Thanks!
KOOM BY YAH
Thanks!
oilburner00
Sorry to bring up a dead thread but I am just now getting around to fix it. So the crankcases do not need to be split then, correct?
- 6 Riders
Nope....Just the inner clutch cover.
oilburner00
Great, thanks! I'm sure I will be back with more questions.
- 6 Riders
Look up water pump replacement, there's help in there.....and replace your water pump seals while you have it apart.
