1. (The easy one) I realized the lever that attaches to the KIPS governor was all sort of bent and was probably never engaging my power valve. So order a new one and back in business.
2. (The sucky problem) While buttoning everything back up, I have everything all lined up (with the exception of the bent lever bit I talked about above), and making sure that thin little washer on on the kickstart shaft I try to reinstall and torque my ride side cover back on...two problems result.
First problem is my shift shaft is hitting against my cover and binding up, meaning I cannot shift the bike it is stuck up and will not move, release tension on the cover and it is just fine(it even marred the cover it was hitting so hard) which also results in cracking the frickin cover...oh well I did something wrong I think and order a used cover off Ebay for 150.00, and the same problem is still there still binding up and probably won't seal in the oil without cracking the new/used cover, so needless to say I have a cover with a a fresh coat of yamalube sitting on my bench and a bike that I cannot ride...frustrated!!
So the facts,
1. The doohickey lever is still bent, could this be throwing things off on the other side of the cover? I am ordering a new one.
2. Is that thin little washer on the kickstarter worn out and not leaving enough space?? Maybe I am missing a washer, I know it goes between the inside of the cover on the kickstart shaft...
3. I put on a fancy new shift lever and had a hell of a time getting the old shifter off, it still has play back and forth, I doubt I screwed up the shift shaft as it still runs through the gears with the cover off or loose.
What am I missing? I will try and post some unremarkable photos tomorrow...but am hoping for some input from the Kdxperts, and really hoping I don't have to pull my clutch basket and the shift shaft. This is a almost 20 year old bike and in doing this routine maintenance along with cleaning my power valve and finding even more broken parts, it's getting hard to justify fixing the old girl.
I have an order ready to go on bike Bandit of the doohickey lever, a washer and a new gasket for good measure. Just trying to figure out if I need to order anything else.
