Hello
Can someone tell me what the carb mods are that rb does to a carb from a 91 kdx?
I'm from belgium so its crazy to send my carb
But i want to know what he does with the carb so that i can look for someone that could do the "same" work
Pictures are also very welcome
Carb mods from rb?
- Been thanked: 10 times
Jasper
- Country: Belgium
Re: Carb mods from rb?
They clearance the slide so it works with the divider plate as far as I could tell looking at mine. The jetblock work is all internal, so not sure what they do there, I would guess maybe polishing and clearancing the air passages similar to when you polish a port job in a motor. The 2 big things are boring the carb and installing the plate. Those two things alone should be able to be done by most machine shops and make the biggest difference. If I was looking for an outside source thats what I would do and not worry about the jetblcok stuff.
