where to buy jet block gasket 2000 kdx200
two-stroke-brit
Post by two-stroke-brit »
as above , is there a preferred distributor?
T I A Mark
She might not be pretty but always a fun ride !
Tyl3r
Re: where to buy jet block gasket 2000 kdx200
Post by Tyl3r »
Sudco sells them too, but they aren't as easy to deal with. Catalog pg 137, p/n 021-532. Price is the same from both places.
Has thanked: 71 times
Been thanked: 20 times
bufftester wrote:Sudco sells them too, but they aren't as easy to deal with. Catalog pg 137, p/n 021-532. Price is the same from both places.
Thanks for sharing your shopping experience. I assume I will order one at some point and did not know which wold be better to deal with.
Tyl3r
Post by Tyl3r »
jets r us isn't bad at all to deal with. I've ordered from their site a few times with no issues. Plus, they usually send a sticker... im a sucker for those :tonqe:
Free HP! lol
Ok, I give up. I'm going to ask the stupid question. I've disassembled my carb multiple times, looked on every carb blow up diagram I can find. Nowhere can I find a reference to anything called a "jet block gasket". I have no idea what the hell you guys are talking about. I'm beginning to think I've fallen victim to the KDX version of a snipe hunt! Somebody please set me straight!
The simple answer is because the jet block gasket is not shown on any blow up diagrams and is not considered a normal wear item. It is located under the jet block which is held on by a couple of security torx fasteners. You have to remove those fasteners and then jet block will come off with the gasket underneath. The only real time it would need to be replaced is if someone hot dipped the carbs, that eats the rubber seal up and leads to air leaks internally which will give you fits trying to jet it. It looks like Image
two-stroke-brit
SUDCO are out of stock until mid march. :sad:
just fyi.
cheers mark
Davenay67
Post by Davenay67 »
This is where I got mine. Good service.
A good opportunity to stock up on extra jets if needed, or carb rebuild kits.
bufftester wrote:The simple answer is because the jet block gasket is not shown on any blow up diagrams and is not considered a normal wear item. It is located under the jet block which is held on by a couple of security torx fasteners. You have to remove those fasteners and then jet block will come off with the gasket underneath. The only real time it would need to be replaced is if someone hot dipped the carbs, that eats the rubber seal up and leads to air leaks internally which will give you fits trying to jet it. It looks like Image
Thanks, Bufftester! Simple. I appreciate the education.
