1998 kdx 22r down on power //?
garycrafton
Country: UNITED STATES
Post by garycrafton »
OK,, I HAVE A 1998 kdx 220r ,,that just will not quite get to the high rpm range ,,don't miss starts right up, I cleaned the carb..any one have any idea ,,I think its the power valve system ,,I have to admit I don't know much about it ,,
diymirage
Re: 1998 kdx 22r down on power //?
Post by diymirage »
what are you comparing it too ?
the 200 is the screamer, the 220 has more torque down low and doesnt like to rev
you can pop the screw on the KIPS cover off and see if it opens...it could be gunked up
Has thanked: 83 times
Been thanked: 20 times
Welcome to the forums. Do check the power valve system, reeds, etc.
garycrafton
diymirage wrote:what are you comparing it too ?
thank ..you ,,I have had a few kdx 220 and 200 bikes this one just does not produce the power I know it should
garycrafton
I am gonna look at the kips today just not sure just how it should work ,,and I don't want to tear it all down this week as I have a ride planned this weekend
garycrafton
garycrafton wrote:I am gonna look at the kips today just not sure just how it should work ,,and I don't want to tear it all down this week as I have a ride planned this weekend
is there an effective way to clean kips system with put taking the head apart ?
garycrafton
sorry!!!! that was suppost to say with out taking the head off
No. To really clean it, you have to take it all apart.
Tyl3r
Post by Tyl3r »
May want to double check to make sure you don't have a OEM cast piston in there too. I agree about the kips cleaning for sure. Did you play with the jetting at all when you had the carb apart? Maybe its off a bit making it hesitate or bog.
Here is a good thread about how to take apart the entire top end (KIPS included) and reassemble. I didn't know much about it the first time I did it either, but its a straightforward process, its not too bad. Get yourself some Brakleen or kerosene and get to cleaning. Just don't break off the LH thread plastic shaft (seen in the last photo of the original post) http://www.thumpertalk.com/topic/657765 ... to-kdx200/
garycrafton
Jason wrote:Welcome to the forums. Do check the power valve system, reeds, etc.
I have not yet ,,not sure how the kips should work ,,online hunting it up now
garycrafton
Tyl3r wrote:May want to double check to make sure you don't have a OEM cast piston in there too. I agree about the kips cleaning for sure. Did you play with the jetting at all when you had the carb apart? Maybe its off a bit making it hesitate or bog.
No, I just cleaned it did not change the jets ,,not that up on proper jetting
garycrafton
checked reeds,,not powewr valve ,,may try a tear down deep clean and replace ?
garycrafton
just got the thread to load right ,,it is a good one,,thank you
