Rmz fork swap?
Scrandy
Rmz fork swap?
Post by Scrandy »
Hey everyone! I have a chance to buy a full front end from a rmz250. Was wondering if this fork swap can be done or if I should just wait for a kx/kxf to be parted out. The entire bike is still there as far as I know right now so quick answers would be appreciated as this bike probably won't last too long. I have an 04 kdx220. Thanks! :)
2004 KDX220R. I'm Canadian eh.
Scrandy
Rmz fork swap?
Post by Scrandy »
It's a 2005 rmz250 by the way
Friedom
Re: Rmz fork swap?
Post by Friedom »
They're good forks from what I've read. Cross check your stem bearings, stem length, and fork lengths, but if I had a good deal on the rmz I think I'd go for it.
"Fun Wheel Drive"
Has thanked: 153 times
Been thanked: 38 times
Re: Rmz fork swap?
It will work. I think a few on here have done it.
Stem swap, pull em up or shorten em down, will need some material inside the upper clamp stem hole to take up the slack
normal issues covered here for 12 years
Scrandy
Re: Rmz fork swap?
Post by Scrandy »
Jason wrote:It will work. I think a few on here have done it.
When you say stem swap what stem do I need to use? The stock kdx stem?
Friedom
Re: Rmz fork swap?
Post by Friedom »
I would guess the kdx stem as it'll be correct for your steering head.
"Fun Wheel Drive"
Re: Rmz fork swap?
1992+ KX125 / KX250, etc. stems are larger in diameter at the upper bearing. Their upper bearing is larger too. One cannot use the top bearing in the KDX / KLX / KX500 head tube.
People usually use the KDX stem.
scrandy, there are a TON of threads on here detailing it and people who have done it describing their experiences. I think the fork conversion subforum was made in very late 2004 or very early 2005, so about 12 years worth.
Scrandy
Rmz fork swap?
Post by Scrandy »
Hey thanks for the help everyone but bad news, was talking to buddy about it today and the only things I needed are what was bought so far. was everything I needed. Literally everything else is there accept the stuff I need lol That must just be pure bad luck for me.
Re: Rmz fork swap?
UGH! Bad luck! :cry:
