Yes, another fork question..
Tilts
Country: CANADIAN
Post by Tilts »
Ive tried to read through as much info as poss on here...there's so much that mu tiny bird brain is fried.
am I right in thinking, that if I get hold of a det of KX500 forks, the original KDX caliper and wheel are compatible with the forks? just need to pop the KDX steem out and press into the KX500 bottom yoke..correct.
sorry for treading on old ground.
javjacob
Re: Yes, another fork question..
Post by javjacob »
97-04 KX 500 is a direct bolt on. No stem swapping
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Tilts
Country: CANADIAN
Post by Tilts »
And I'll still be able to use my original wheel with axle and calliper?
Tyl3r
Post by Tyl3r »
caliper yes, wheel and axle no. You will need to source them from a kx125/250/500 in the same year range. When I did this swap on my old KDX, i reused the KDX caliper with the 500 forks and i believe the wheels came from a 250 IIRC
