Kdx start issue
carlmarshall81
Country: Not sure
Kdx start issue
Post by carlmarshall81 »
Hey i just rebuilt to end of my 89 kdx 200 have added dual stage reeds, high ignition coil ,fmf fatboy pipe ,moose racing torque spacer ;movd throttle needle to centr slot its a pwk 35mm keinin striker has a 48 pilot jet and a 152 main but its so hard to start but will seem to go strait away with engine start dwn plughole thn after tht starts first kik evry time its got me lost
carlmarshall81
Country: Not sure
Re: Kdx start issue
I hav no idea were the probkem is iv treid all things i can think can anybody give me any suggestions i also forgot to put in last post i hav air screw at 1.5 turns and new power valves
pumpguy
Been thanked: 2 times
Kdx start issue
Post by pumpguy »
Have you done compression and leak down tests?
carlmarshall81
Country: Not sure
Re: Kdx start issue
Nope but new piston new rings and gaskets were wld a leak be likley to b found and how do u so test and how much compression shld it hav
carlmarshall81
Country: Not sure
Re: Kdx start issue
Also hav pjt a hotter plug in dows tht matter
pumpguy
Re: Kdx start issue
Post by pumpguy »
Google searches on these questions will provide the answers.
Has thanked: 179 times
Been thanked: 46 times
Re: Kdx start issue
Is the carb new or used? Maybe it is a dirty carb?
NGK BR8ES is fine for most 1989 - 1994 KDX200's.
Jasper
Country: Belgium
Re: Kdx start issue
Post by Jasper »
Jason wrote:Is the carb new or used? Maybe it is a dirty carb?
My manual says br9es... I know the number has something to do with the temperature, but can you explain whats the difference and when do you choose 8or 9
Re: Kdx start issue
Float level ok?
8 is for trail riding, 9 maybe for high speed dessert or maybe MX. I never could get mine too rub right and switched tip an 8, plug temp turned great from black
