89 kdx200
Stg249
89 kdx200
New to the group. Just scored an 89 kdx 200 for $150. It's been setting for 3yrs. Cleaned the carb and it busted off the second kick. Runs great, but water pump seal is leaking. Seat cover and tires are dry rotted but has fmf fatty pipe and boysen rad valve and plastics are in great shape. Stripping it to do a frame up build.
- Has thanked: 159 times
- Been thanked: 39 times
Re: 89 kdx200
Welcome to the forums. That is a great story.
- KDXohio
Re: 89 kdx200
Nice! That's a great find!
Dekon
Re: 89 kdx200
Nice! I did the same as you, got an '89 off of CL for $250. It ran when I put fuel in it so I did a ground up restoration on it. You should post up a build thread on it.
david
- Country: UNITED STATES
Re: 89 kdx200
Good score!
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
- jaywylie
