How do you pull a KDX flywheel?
KDXMainer
- Country: Us
wondering if there's a video link someone has of this being done? I googled this question and couldn't find anything specific to the kdx. I have no spark and all my compontants wires and grounds are fine. I was told it could be a timing key is sheared. Need to get this flywheel off. Thanks Mike.
2006 KDX200
1998 KDX220
1998 KDX220
KDXMainer
- Country: Us
My mechanic friend says water behind the flywheel cover would not cause the no spark issue. He be leaves my flywheel key is seared do to the po not torking the flywheel correctly. What do you guys think? Not getting any answers today. It's Saturday what are you guys out riding or something instead of hovering over the computer?
2006 KDX200
1998 KDX220
1998 KDX220
- KDXohio
Re: How do you pull a KDX flywheel?
To pull the flywheel remove the flywheel hold down bolt and use a 27mm flywheel puller
DO NOT HIT THE FLYWHEEL!!
- KDXohio
Your stator coil resistance should be
300-450ohms between the white/red and black wires
1.76-2.64ohms between yellow and black
- Has thanked: 50 times
- Been thanked: 17 times
Ha. U get what you pay for on advice.
27 x 1 left hand puller, cheap on ebay
KDXMainer
- Country: Us
Gonna by an air tool to remove flywheel nut. How many foot pounds should the gun be to quickly zip it off? Also going to hit all the parts stores hoping one has the KDX puller. I spent 3 bucks and bought a test light. Lighting coil works ignition coil does not. Should have done this before buying a new CDI. Ohms are 9.04 M on my meter. Not sure if that's good or bad.
2006 KDX200
1998 KDX220
1998 KDX220
- KDXohio
Any 1/2" impact should be plenty powerfull.
pumpguy
In addition to a flywheel puller, you will need a way to hold the flywheel when torquing the nut.
For this I use a Vice Grip #20R chain clamp pliers. Other brands of similar tool are also available, and you may be able to rig up something else to hold the flywheel.
Torque up the flywheel nut to 47 ft-lbs.
Also, for the stator plate, these should be torqued to 87 inch-lbs and secured with non-permanent thread locker like blue Loctite 242 or similar.
bazwalton
Not a video, but some pics of the extender screw I made to make the 27x1 flywheel puller fit the deep crank on an E series.
https://www.facebook.com/Enduromotorcyc ... 4782190792
https://www.facebook.com/Classic-Mann-952895831458690/ Kdx racing and restoration.
Kdx175x5 Kdx200x4 Kdx220x2 Kdx450. Kdx200AF.
