Does 2 stroke oil go bad?
mwoj
Got my bike going after a rebuild. Didn't have any newer 2 stroke oil on hand so i used a small container from the 1990's. Yes it was old but new. Was only good for 1 gallon of gas. But considering this is my bike first time running in quite some time, I have nothing to compare it to. Will it make a difference?
- KDXohio
Re: Does 2 stroke oil go bad?
IF it was sealed should be fine, opened and it wI'll collect moisture over time
