Fly wheel weight
jjavaman
Fly wheel weight
Hi kids! I find the back tire spinning to much after getting the mods done. Anyone running a fly wheel weight? Will a weight help much or do I need to just get used to the mods? I love it on fast stuff, just find in the tight stuff I'm lighting up the rear end to much?
canamfan
Fly wheel weight
I don't use a weight maybe your gearing is to low, what gearing do you run. I'm using 13/49.
ohgood
Fly wheel weight
jjavaman wrote:Hi kids! I find the back tire spinning to much after getting the mods done. Anyone running a fly wheel weight? Will a weight help much or do I need to just get used to the mods? I love it on fast stuff, just find in the tight stuff I'm lighting up the rear end to much?
it will definitely increase traction and prevent stalling at lower rpm, but it's not magic, if you tell it to spin, it will
cornishwrecker220
Fly wheel weight
I run a 10oz Stealthy flywheel weight on my tuned 220 & its great. The bike still produces the same HP just not so snappy....perfect for those steep slippery climbs!
You can lug a low gear virtually to the point of past stalling, & it also seems to give the motor some extra momentum when climbing over fallen obstacles too....if you ride tight single track wooded areas & seldom get out of 3rd or 4th gear then a weight is ideal...it only takes minutes to fit & you can remove it just as quick if you don't like it .
'03KDX200
Re: Fly wheel weight
Also you might need to just add more traction to the rear wheel. That will keep you from "lighting up the rear end" also. I just put on the amazing and cheap Tusk Recon Gummy Hybrid tires on my KDX. Holy crap, what a traction upgrade! I literally have twice as much traction on both front and rear as I did running Maxxis motocross tires, and far better feel for the dirt too. Designed for low pressure too, which vastly increases your contact patch, which vastly increases traction. It feels perfect at 6 psi rear, 8 psi front. $110 for both tires.
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Yup, old thread. However, since it has a fresh post, I moved this topic out of the RB section as it really isn't an RB related topic.
- Goat
I can’t say about flywheel weight, but had similar experience as 03, using the Kenda Equilibrium. I am also running 6psi rear in the woods, now. It about tossed me off the trail couple times, getting used to the traction.
- rungrandpa
- Country: U.S.A.
- Has thanked: 1 time
I saw an interview of a hard enduro rider. They asked him what the biggest advancement in motorcycles were over the last 10 years. He said tires showed the biggest improvement.
