Do You Recognize these forks?
IDRIDR
Post by IDRIDR »
Hello collective.
Do you recognize the forks in this ad?
http://twinfalls.craigslist.org/mpo/5654678978.html
Would they be something I should be interested in for an '03 KDX220?
Thanks for the input!
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
Tyl3r
Re: Do You Recognize these forks?
Post by Tyl3r »
I believe they used those on the KDX's in 93-94 on the E-series bikes (the generation previous to yours). I'm not 100% if they would be a direct swap for yours or not, but I am fairly positive that your current triple trees will not work with those. A quick search on here would let you know, I know I've seen others ask the same question... or someone will chime in!
If you want an easy USD fork swap, see if you can find any KX500 front ends. I put forks, trees, and a wheel from a 2001 on my old bike and everything bolted right up with no modifications.
Has thanked: 102 times
Been thanked: 26 times
1993 - 1994 KDX200 forks
You will also need the triple clamps, brake hose and/or caliper, fork guards, fork guard guides
NOT sure on front wheel interchange
I would suggest skipping it due to cost vs. benefit
Maybe just look in the FS forum for that guy's KLX300 front end stuff?
IDRIDR
Post by IDRIDR »
Thank you both very kindly. That's what I needed to know!
Will be passing on this one.
2014 Suzuki DL1000.
Not really a bad price for forks, but since you need a front end, not just forks, that makes a difference.
Friedom
Post by Friedom »
I'd consider them if they were local - since I have a bike with them already.
"Good job, guys. "
