Do I need a special tool?
 - Has thanked: 48 times
 - Been thanked: 15 times
Re: Do I need a special tool?
Hello from the bar!
Yes. You need to remove the compression adjuster assembly. Hopefully, you have not tried to slide hammer them apart, yet. If so, the bushings are probably damaged.
After removing the compression adjuster assembly and then cartridge, boil up a couple of gallons of water and pour it over the seal / bushing area. It will cause it to expand a little and be easier to separate with less damage to the bushings.
				hoosierKDX
Thank you for the response. Yes, I've tried to slide hammer it out, but I'm replacing the bushings and seals.
				canamfan
Did you remove the compression adjuster from the bottom of the fork? It's a 14mm allen,  usually an impact wrench will get it out otherwise you have to have the special tool or make one like I did.
				hoosierKDX
I tried and it just spins..... ordered the tool from FRP off-road......it's almost been a week and I'm still waiting for the tool...... their shop is only  4 hours away from my house....
				kenpowell
This trick will usually allow the compression adjuster to be removed.
1. Turn the fork upside down and stick the axle into the fork lug for additional leverage
2. Apply your weight to the axle and push downward - this will push the spring against the damper rod to keep the adjuster from turning
3. Use an air impact driver to remove the adjuster.
Ken Powell
2012 KTM 300 XC with YZ SSS cartridges in the WP tubes
2003 YZ265WR with 2005 AOSS forks
2003 KX125 / KDX200 motor with YZ SSS forks
First Motorcycle - 1963 Harley 175 Scat
