flywheel weight?
- parker72001
flywheel weight?
Has anybody used this? Does it really help stop stalling and make low rpm's that much smoother. It's $90 and I was just wondering if it's worth it. If anyone has it, how tough is installation? It seems like it would be fairly easy.
Thanks
Parker
Thanks
Parker
Parker Woods, 20 years old,
'04 KDX 220R
'04 KDX 220R
- bradf
Q: Used it
A: Yes use search for FWW
Q: Does it help stop stalling
A: Yes. use search for FWW
Q: Does it make low RPM smoother
A: No, proper jetting does this. It will keep the motor turning a tad longer due to the inertia of the added weight. Locking the rear on downhills still kills the motor.
Q: Is it worth it
A: Yes, if you are in a slow tight snotty area where power delivery needs to tamed. (this is another question you could have asked) use search for FWW
Q: How tough is the installation
A: Very easy. use search for FWW see CC's tips
In short, do a search for FWW, there are a few of us that use/used them and wrote on here about them.
Q: Is it worth it
Yup.
...if you wanted another opinion................
...sometimes I just kill myself.........har har har....
re Q3:
Locking the rotor does kill the motor. The balance between that point and the motor running 'longer' due to intertia changes considerably. It is considerably more difficult TO lock the back brake with a FWW.
Anecdotal input.....
Without a FWW it used to take hardly a touch of brake to kill my bike on downhills. Obviously...that sucks. When turning the tranny by the rear wheel (usually it's the other way 'round, right?) it's tough to shift, you lose the use of the little engine braking you have, you're not setup to twist it and go..obviously.
After the FWW? I have to conciously intend to apply the brake hard enough to do that. The inertial aspect keeps the motor running even when you would swear it SHOULD have stopped. I realize that sounds kind'a stupid, but you will know what I'm talking about if you get one.
The 'bottom end' part of things is 'smoothed out' to some extent. That's largely a semantics point..I am picking the nit. Yes, jetting and other configuration make for a 'smooth' low RPM range..so does the added inertia of a FWW in a slightly different fashion.
There is more than one choice of brand of weight, I believe. That may not be true for the KDX..but certainly more than one outfit makes FWWs. Get one from Steahly. It's easy to put on, it's removeable, it works.
re Q3:
- skipro3
- m0rie
- skipro3
It's a Steahly off my 1999 KDX 220. I don't remember the actual weight of it, but not hard to check I suppose. Check to see if it will fit your bike from that info and it's yours. I suppose some website should be able to list out a part # for the two bikes we have and let you know if it's the same.
- m0rie
- skipro3
- Mr. Wibbens
Back in the day when I used to ride my KDX.... w/a Steahly FWW
I seem to remember that sometimes while going up a steep hill, if the motor stalled, sometimes when I'd pull in the clutch it would refire!
- skipro3
