Front brake rotor is getting pretty thin (about 20% left).
What is everyone's vote?
Need replacement front brake rotor. Opinions????
- 19Delta
canamfan
- 6 Riders
Re: Need replacement front brake rotor. Opinions????
What year bike?
- 19Delta
Good point! Sorry. H series, 2003.6 Riders wrote:What year bike?
cornishwrecker220
I run a wavey front rotor off a 2005 kxf 250, the only mod you need to do is just drill open the mounting holes as the kdx bolts are larger than the kxf ones ( kxf I think are 5mm kdx are 6mm) I use a little loctite to secure.... Been running it now for the past 3 years without any problem.
- 19Delta
I have no problem drilling the holes out, but curious, why not just run a KDX rotor? What's the benefit of swapping?cornishwrecker220 wrote:I run a wavey front rotor off a 2005 kxf 250....
cornishwrecker220
Here in the UK there aren't many OE front rotors for the kdx, the ones that are, are too expensive...£70 ( $150 )... I can buy a pattern kxf disc new for £40 & it look good too !
- 19Delta
Makes sense! I'll check pricing here in USA too before I order! Thanks!
newbbewb
I bend rotors on a frequent basis so I stopped buying the $100 EBC and started using tusk. Same brake feel, same stopping power....$45 cheaper.
