Hi all, I got my basket case KDX200 together and running, and now I've noticed a slow leak from the drain plug. The drain plug is the correct one. The previous owner put two crush washers on there that were not the right part, so I got the correct one from my Kawasaki dealer but she's still leaking. Is this common with the KDX? Any easy solutions?
Thanks
Slow leak from transmission drain plug
Posted: 02:42 pm May 30 2016
by canamfan
I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
Re: Slow leak from transmission drain plug
Posted: 04:22 pm May 30 2016
Any chance the threads are a little stripped or damaged?
Did you use a torque wrench?
Posted: 04:52 pm May 30 2016
by C George
If the threads are messed up , this product works good . Everything has to be clean and dry.
Posted: 05:04 pm May 30 2016
Is that going to be suitable for frequent oil changes??
Posted: 07:03 pm May 30 2016
by Sullyfam
IMO - Don't do anything that makes removal difficult.
Sounds like the threads are messed up. Use pipe compound or Teflon tape. Is that doesn't work you can try a Heli-coil.
Posted: 04:06 am May 31 2016
by C George
Jason wrote:Is that going to be suitable for frequent oil changes??
Good thought ,,,, a helicoil has to be tougher.
Aluminum drain plug holes are a pia.
Posted: 12:50 pm Jun 01 2016
by sthoward
canamfan wrote:I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
Plumber's tape did the trick, no more drip drip drip. Thanks!
I've never had to do that before on any previous bike, and given the condition the bike was in when I bought it (non-running, poorly maintained) I suspect the threads are a little messed up.
Posted: 01:02 pm Jun 01 2016
Thanks for reporting back.
Posted: 01:07 pm Jun 01 2016
by eprovenzano
Love it when the OP reports back problem solved...
Posted: 01:55 pm Jun 01 2016
by sthoward
It's the least I could do in return for the help I've received on this forum. kdxrider.net ROCKS!
