Slight idle hang
Questions and Answers about the best carb and Head mods available for the KDX.
Mnmonster
Slight idle hang
Post by Mnmonster »
I just did a top end rebuild on my 97 220 this winter. New wiseco piston, boyseen reeds, all new gaskets, and I also had Ron mod my carb and head. Right now I'm running a 40 pilot, 150 main, needle clip 4th from the top, air screw 7/8 turn out. Bike will start on the first or 2nd kick, no choke needed. Idles great. However when blipping the throttle it seems to take a bit too long to settle back down. Its not excessive but it does take longer than it did before. I have double checked everything was tight around the head and intake. I don't believe I have an air leak anywhere. Am I reading too much into this or should I keep digging? Not sure where I should look next. I also did a plug chop test last night and the plug was still pretty white, so I'm thinking I need to go up a size on the main. Any thoughts appreciated. Thanks.
jjavaman
Re: Slight idle hang
Post by jjavaman »
I did the same thing last year and had the same problem! It was a air leak for me, one of the bolts on the reed block was not tight.
Has thanked: 16 times
Been thanked: 24 times
Slight idle hang
Ron's normally pretty good about getting the jetting real close for you. I would suspect a leak as well.
Jaguar
Country: Ecuador
Post by Jaguar »
check the crank seals for a leak
Mnmonster
Post by Mnmonster »
Jaguar wrote:check the crank seals for a leak
I would like to think that this is not a strong possibility as I did not have this problem prior to my rebuild. I will triple check all the gaskets and bolts though.
ohgood
Slight idle hang
Post by ohgood »
Mnmonster wrote:I just did a top end rebuild on my 97 220 this winter. New wiseco piston, boyseen reeds, all new gaskets, and I also had Ron mod my carb and head. Right now I'm running a 40 pilot, 150 main, needle clip 4th from the top, air screw 7/8 turn out. Bike will start on the first or 2nd kick, no choke needed. Idles great. However when blipping the throttle it seems to take a bit too long to settle back down. Its not excessive but it does take longer than it did before. I have double checked everything was tight around the head and intake. I don't believe I have an air leak anywhere. Am I reading too much into this or should I keep digging? Not sure where I should look next. I also did a plug chop test last night and the plug was still pretty white, so I'm thinking I need to go up a size on the main. Any thoughts appreciated. Thanks.
the mixture and clip position say your pilot is too lean. richen up the pilot a few measures, retune the clip and mixture, i bet it doesn't hang anymore.
Jaguar
Country: Ecuador
Post by Jaguar »
I disagree since he can start it without the choke
Mnmonster
Post by Mnmonster »
Jaguar wrote:I disagree since he can start it without the choke
This is where I get a bit confused as well. Starting without choke would lead me to believe I am rich...however the hanging idle would point to being lean...kind of contradicting.
Mnmonster
Post by Mnmonster »
Ok I tried swapping in a 42 and a 152 and then also a 38. No change as far as the idle goes. Same slight hang. See video below.
Am I making too much of this? Right now I have the 38 with the 152 main. I've got some spooge with the bigger main but the bike just rips from 1/8 throttle on up. Slight bog from idle to 1/4 when accelerating hard.
ohgood
Post by ohgood »
i think you're right, too.
meaning.... there is weird stuff happening that should not happen. he's rich when first started (start without choke) and lean once running (idle hanging).
i bet there is a air leak and jet block / fueling issue happening.
Mnmonster
Post by Mnmonster »
I tried tightening everything again, reed block, cylinder, and head nuts. No change. I had Ron replaced all the gaskets in the carb, including the jet block.
jjavaman
Slight idle hang
Post by jjavaman »
Does the slide "snap" shut when you blip it?
Mnmonster
Slight idle hang
Post by Mnmonster »
jjavaman wrote:Does the slide "snap" shut when you blip it?
Yes it opens and closes smoothly and doesn't hang up.
shoe757
Post by shoe757 »
I would lube the cable just for giggles. It's quick and easy. Other than that I would say rich on the pilot or leaking fuel passed somewhere.
02 Kdx220
97 Kdx200/220
04 Kx250/500
01 Kx250
01 Kx100
13 Klx140
12 Teryx4
11 kfx450r
05 Vulcan 2000
04 636
93 Cbr900rr 8.37 ET
96 Rm125
Mnmonster
Post by Mnmonster »
Still chasing this. I am not loosing any transmission oil or coolant. No visible leaks of any kind. I've tried spraying wd-40 and carb cleaner all round the intake, base and head gaskets with no change in idle.
Yesterday I took the reed block off to inspect the brand new reeds I installed when I did the rebuild. Here's a pic. You can see a bit of light in the corner. Is this enough to cause an issue? And if so, I believe this would show up as a rich condition, not lean that I am experiencing, right?
Also I snapped a pic down into the piston to find some real nice gouges on my ~5 hour piston. :?
Starting to lose interest in chasing this stuff.
Tedh98
Post by Tedh98 »
Wow on the piston picture. What is your warm up procedure? Is this the first time with a forged piston?
I only see two if the four corners . . . . but I havent seen gouges that deep or narrow with a 4 corner siezure.
Mnmonster
Post by Mnmonster »
Yes first forged piston. Had the stocker in it when I took it apart.
Warm up, I just let it idle for about 5 minutes then ride easy for a minute or two. Then ride as normal.
Mnmonster
Post by Mnmonster »
Can anybody tell me the inner diameter of the exhaust and intake? I'm going to make a leak down tester and need to order some plugs.
Mnmonster
Post by Mnmonster »
Built myself a leak down tester. I did have some small leaks at the reef block but got those sorted. However I have a pretty significant leak still. Lose about 1 psi per minute. Can't seem to locate anything around the intake, spark plug, head, or base gaskets...this would lead me to my crank seals I suppose :sad:
I have not lost any tranny oil, so I assume my problem lies with the left (flywheel side) seal. Is there any way to verify before diving in? I know the bearings and seals are relatively cheap, but what would I be looking at for labor if I brought just my motor in to get split and seals and bearings replaced?
Mnmonster
Post by Mnmonster »
Starting tearing everything down. My piston is in way better shape than I thought. The previous picture had me worried. Here are some pics.
Those gouges in the earlier pictures aren't gouges at all. Can't even feel them with my fingernail.
Thoughts?
