Torque Specs?
waldo177
Torque Specs?
Post by waldo177 »
According to my cyclepedia manual it says to torque the 4 jug nuts to 18 ft lbs using a crows foot on the torque wrench. My question is, is this calculating for the crows foot because when torquing with a crows foot it changes force point (sorry I do not know correct term for this) or will I need to recalculate? Thanks for the help just want to do it right the first time
Sent from my SM-S920L using Tapatalk
Has thanked: 193 times
Re: Torque Specs?
You may want to look at the Motion Pro torque adapter
I think the key is that it is at a right angle.
Corey
Re: Torque Specs?
Post by Corey »
I use the Motion Pro adapter and yes the key is to have it at a right angle relative to your torque wrench then you do not have to make calculations.
