90% complete
- layoutd
90% complete
enough to try it out, no headlight, etc. but together and riding. not enough trails around to give it a good try, but i did notice that the front end seemed a lot lighter. it was more prone to come up and easier to make come up. i am guessing that is due to less weight at the axles. got watch the way i ride until i get used to it.
Eatin' ain't Cheatin'
Sprung vs. unsprung weight.... makes a difference.
Is it also due to the front being pitched a bit higher???
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- KDX220PHIL
- m0rie
I thought most people took that "pitch" out by spacing the top clamp up so the forks could be slid up higher in the clamps?
Did you happen to measure your 'before' setup to help with getting the 'after' setup in the same neighborhood?
Mentioned before...but I like it..so I'll repeat it.
Figuring the height of the bike by measuring axle-to-clamp does have some problems between the KX and the KDX frontend. I don't think that's a very meaningful way to get the job done.
I set a level on my bike before I started..marked the spot on the seat (or tank..same) where the level needed to be set to read 'level'. I setup my KX frontend to 'read' the same.
re: Sprung vs: unsprung
Yep. It does make a big difference. I do wonder if that ends up a positive or negative in the case of a fork swap. The inner tube (either fork type) I'll bet is heavier than the outer tube.
I have nothing to base that on..even though the inners are smaller dimensionally speaking, I think they would be heavier.
Still..your frontend seems lighter because it's taller, I'll bet. Not usually a good thing on any uphill....
I've often found it farily easy to 'wheelie' going downhill. Well...if you want to apply that term to the rear wheel coming up! (going over?)
Maybe that's a 'stoppie'.
- layoutd
i did not measure the before and after height, probably should have, but didn't. i have the spacer under the triple clamp and measured 7/8" from the top of the clamp to the top of the fork. the bike feels the same when sitting, not that i would probably notice, only been riding a motorcycle since may '04, kinda like it light up front. i did a little hill behind the house and did notice that i needed to sit up farther on the seat, but i attributed that to being lazy and not getting up on the pegs good. maybe i will leave it like this for a bit to encourage me to stay up on the pegs and more forward on the uphills. a recent enduro i did, first as well, i noticed that i was holding on with my navel entirely too much. i'll ride like this for a while and force myself into better form. not sure that i could go much further up on the fork anyway.
- m0rie
IF you used a spacer...and IF you're 7/8" up past THAT...you should be right close to a 'correct' attitude.
Well, that's close to my setup..and I'm level.
Maybe your bike just runs great and hooks up better!
Heck...may as well think on the positive side.
Let us know how you like it after summore riding..........
CC... you think the inner tubes are heavier than the cast aluminum receivers? I don't think so and that is what is being sprung besides the internals. I'm pretty sure the KX forks sprung weight would be much less.....canyncarvr wrote:re: Sprung vs: unsprung
I thought this is one of the reasons that the switch to USD's was done.
