I'm in quite the pickle with my klx 220r. While accelerating rapidly this past summer I thought I had blown the motor. I had shuffled quickly up to 4th or 5th when I heard a loud knocking in cadence with the rpms, I lost power and the bike died. I got off the bike and looked around. No immediate signs of oil and since we were edging on bfe I kicked it over and it started right up. I puttered slowly home 5-6 miles, besides a lack of umph it sounded fine. It starts and drives. I found this crack (please see pics) maybe 1/2 to 2/3 the width of a U.S. dime.
There's two possibilities: option 1: I hit something (a rock for ex.) along the case beneaath the actual crack, at or near the green fleck in the photo, hence causing the case above to fracture outward pivoting over the case bolt. The whapping sound I heard was the piston running dry of compression hence losing power. Option 2: Something (what exactly? - roller bearing for ex.) was dislodged internally and got stuck next to the casing causing the fracture. The sound I heard was the damage being done and like the alien jumping out of that dudes chest, the misc part was just simply trying to get out.
Geesh, quite the pickle. So I could tear it all apart, or if its the consensus view among the klxers, that its very unlikely the bike all the sudden started spewing parts, I could find a patching method (ultra high temp, high psi metal opoxy, or aluminum weld/braze/soder) put some oil back in her and let the good times roll. get a magnetic oil plug and watch for pieces? hum... now.. how do I upload photos?
