Front axle removal
Posted: 09:42 am Oct 17 2015
by bultaco4ever
Is there a trick to removing the front axle? (my manual hasn't arrived yet...sorry to ask such a simple question)
Front axle removal
Posted: 04:51 pm Oct 17 2015
by dualscotty
No trick at all just take the nut all the way off and remove the bolt. Use some pliers on the bolt and spin it while your pulling it out.
Re: Front axle removal
Posted: 05:09 pm Oct 17 2015
by bultaco4ever
P.O. has neglected maintenance on this bike for a while. Axle is kind of frozen in place....I'll get a bigger hammer and some WD40 and a some propane heat.......thanks.
Posted: 09:26 am Oct 19 2015
by bultaco4ever
The bigger hammer and propane heat did the trick. I almost deformed the threaded end of the axle but not quite...still usable. Wire brushed the crud off of the axle and inner parts...added a little grease...good to go.
