I hate to ask, but is this too tight for a 220 ring end gap? Manual states .012" minimum, but Wiseco insert states .004" min per 1" bore which works out to .011".
The .011" feeler gage slides right in and the .012" won't quite go all the way in so it's somewhere in between. This is for a freshly replated cylinder and new Wiseco piston so I don't want to take any chances.
Thanks,
Pete
Is .011" too tight for ring end-gap on a 220?
pw455
ohgood
Re: Is .011" too tight for ring end-gap on a 220?
stone the ends if you're worried. it tak won't take much to take off 2-5 thou.
pw455
Thanks for the reply. I don't have any stones, but have a set of fine jeweler's files I can use.
Pete
Pete
- Tedh98
- Been thanked: 2 times
If the math works out to .011 and the .011 feeler slides in, I'd leave it alone. Why risk screwing it up if it is within spec?
- Has thanked: 13 times
- Been thanked: 23 times
I believe the manual calls for .3 mm minimum, which works out to .0118". So the .012" feeler gauge not quite fitting is actually pretty much perfect.
pw455
Yeah, I think I will just leave it. I'm guessing it'll open up pretty fast during the initial break-in.
Thanks for the replies,
Pete
Pete
