Kenda Eqillibrium
chippy
Kenda Eqillibrium
Anyone try one of these yet?
They look good. A cross between a knobby and a trials tire. They are very tall and soft, but are reported to wear well. I am just looking for some real world input before I try one.
http://powersports.kendatire.com/en-us/ ... uilibrium/
CAL-kawi
Kenda Eqillibrium
If you ride woods roots and rocks, and can get your hands on one, I'd go for it! Looks like a great tire. I haven't been able to try one yet, but wouldn't hesitate if it was available where I buy. I've been following the reviews, and they're all positive. I'm not really a knob thrower, prefer to have traction to get the front up at will, but I'm Leary of the full on trials tires where I ride because the woods here are steep and loamy. I think this tire would give the steep downhill braking that is needed here, plus the traction and long life of the trials.
Marylander
Re: Kenda Eqillibrium
I've got one on my 00 kx250 and it is pretty awesome for the east coast rocks that I ride. I've only done 1 ride on it thus far but I'm pretty pleased.
ohgood
Looks like a good one to try.. I'm petty happy with a cheap sr241 from shinko, but won't mind a better bite, just like always.chippy wrote:Anyone try one of these yet?
BlackMist
Rat Boy D
Kenda Eqillibrium
How does the tire work in the mud? Because my brother says that a normal trials tire is horrible in the mud.
Marylander
My expectation is that these would not be bad in the mud but I rarely ride in mud so... Usually any mud I come across is down between rocks so no big deal even for a trials tire. ;)
chippy
Kenda Eqillibrium
Ok, here's the scoop.
I tried the Kenda on my Honda 250x. (my "mountain goat") Wow, a great tire for trail riding. Traction is incredible, braking traction is absolutely amazing! The ride over rocky terrain is very similar to a trials tire, with much better braking control on slippery down hills. I can't say much for mud as it's been record setting dry and hot here this Summer. Right now the wildfires and smoke are out of control and we will not be riding for awhile.
kiohio
Kenda Eqillibrium
Can anyone else update on this tire? I have a Kenda K760 on the rear and a Kenda Millville II on the front.
I would love to get an extra rim and try out the Kenda Equillibrium rear tire or other rear tire.
I ride in SE Ohio and WV so the terrain is super varied from mud to dry sand to clay to rocks to...well you get the picture LOL
I've read that if you spin the tire it doesn't like to grab traction back very well.
Have you all seen the same characteristics?
Thanks,
KO
Thanks,
KO
Marylander
I used mine in mud/rain this past Saturday and it worked fine, apparently better than the similar motoz on a couple other bikes. They're cheap enough to just give one a shot and see how it works for you. They are crazy good in rocks...
kiohio
Marylander
Yeah, I picked up a used KLX wheel for this purpose. You may already know this but KLX wheels work and you can use KX hubs from 02 and earlier if you're building from scratch (newer KX wheels have 3 bearings, not just 2, but work fine). Of course the KX wheels have 19" rims on them to start. I swap wheels between my 00 KX250 and the 03 KDX220 from time to time...
kiohio
I did not know any of that stuff I'm still a newb to anything Kawi LOL
Thank you for the info.
KO
KO
Marylander
I should clarify then, I'm certain the KLX300 wheels work fine and are probably exactly the same parts as used in the H series KDXs. I'm not sure about KLX250s and KLX650 wheels. Hubs from KX125s and KX250s from 93-98 and from 99-02 work (I think the 93-98 is a 2 bearing hub, I'm certain the 99-02 is a 3 bearing hub).
