94 kdx250 won't idle, which timing mark is right.
leejoe
I have changed the pilot jet from a 42,38,35,45. Has a 35 in it now. Idle screw is all the way in, but you still have to crack the throttle to keep it running. Check float level every time I changed jets. Even took bowl off and put fuel line on to make sure the fuel use not leaking out of the float needle valve when sealed. I have burnt out the fmf fatty pipe repacked the silencer. The bike has 185 psi compression, the reeds look to be sealed, it has a new air filter, engine has all new seals and bearings. The timing is on the retard mark after it was rebuilt. There also is no plastis insert in the Reed cage or made on the intake boot. Could either the timing or the lack of the insert cause it not to idle. I'm about to pull my hair out over this one. Any ideals would be appreciated.
ohgood
Re: 94 kdx250 won't idle, which timing mark is right.
potado in the pipe ?
broken silencer?
jet block gasket?
broken silencer?
jet block gasket?
leejoe
Silencer was cleaned and repacked. I took jet block out o ring looks good. Pipe has been been cleaned. I was told by the local Kawasaki dealer that the carb was wore out and they hadn't even seen the carb.
- Tioli
- Country: Tasmania AUS
With out a filler block it will mess it up some but I would have thought more in the upper range.
Try turning your idel screw up on the slide till it idels then play with the with the pilot screw and see it you can find a combo that works.
If you have a air leek any where it will tend to make it idel high and thin that with out a read block could be enough?
leejoe
I have the idle screw all the way in on the slide. I may need to just get a get block oring and try that.
