2000 kdx 220r
joeyd
2000 kdx 220r
Post by joeyd »
hello, new to the dirt bike seen, I just got the bike and it has a crack on the cover, previous owner put a differnt kick start arm on it, what years are compatible for my 2000? can I use one from a kdx 200??
Re: 2000 kdx 220r
any 95-2007 kdx200 or 220 will work fine. What cover is cracked? Lots of good info for new owners in the Newb thread here
joeyd
Re: 2000 kdx 220r
Post by joeyd »
the clutch cover and inner cover.. right where the mate.
joeyd
Re: 2000 kdx 220r
Post by joeyd »
bufftester wrote:any 95-2007 kdx200 or 220 will work fine. What cover is cracked? Lots of good info for new owners in the Newb thread here
I found a service manual on ebay, but it for years 97-05, and I found the inner cover, it is for a 95.. even though the service manual does not put the 95 in there, is the 95 the same as the 97??
6 Riders
Re: 2000 kdx 220r
Post by 6 Riders »
Yes. FYI, the 220 outer clutch cover is a different PN than the 200s. Not positive with the inner cover either. Could just be because they are "different" bikes, but the 220 could have something different with the clutch as well (which I doubt).
joeyd
Re: 2000 kdx 220r
Post by joeyd »
thank you
Re: 2000 kdx 220r
I thought you were asking what year kick start arms are compatible, not covers. The manual is the right one the 220 was made from 97-05 and the 200 from 95-06. The engine covers from a 200 will work on a 220 as far as I remember, the cases are the same as are the clutches. Someone here will either verify or point out how dumb I am :grin:
6 Riders
Re: 2000 kdx 220r
Post by 6 Riders »
bufftester wrote:I thought you were asking what year kick start arms are compatible, not covers. The manual is the right one the 220 was made from 97-05 and the 200 from 95-06. The engine covers from a 200 will work on a 220 as far as I remember, the cases are the same as are the clutches. Someone here will either verify or point out how dumb I am :grin:
Just an FYI, I was looking for the outer clutch cover for my son's 220.....and stopped when I saw different part #s for the 200 and 220. I guess if I get off my LZY AZZ I could actually compare the two....But I wouldn't buy a 200 cover "hoping" that it fit the 220, just because of the PN being different.
joeyd
Re: 2000 kdx 220r
Post by joeyd »
so I got my covers in, Imagebut the clutch cover does not have the lever... i cant see a way to remove my old one to install onto this one, can it be removed
Re: 2000 kdx 220r
IT is a tight fit but it can be pressed out.
joeyd
2000 kdx 220r
Post by joeyd »
i got a 20 ton shop press.lol.. dont think that will work.. what type of press would i use??
Re: 2000 kdx 220r
Use a heat gun and heat up the case around that area and that will help
6 Riders
Re: 2000 kdx 220r
Post by 6 Riders »
That is held in with an oil seal, should pop right out, just [carefully] give it a tug.
Been thanked: 2 times
Re: 2000 kdx 220r
Yeah no press needed. Pull it by hand!
