Question for 220 owners
Tedh98
Post by Tedh98 »
I've been looking for a 220 head. Based on the micro-fiche, the P/N for a 200 head is 11001-1409 and a 220 head is 11001-1410.
Over the last couple of months of looking on eBay, I've found a couple of heads that are listed for a 220 but have the 1409 on them. The sellers have had the cylinders and they were definitely 220 cylinders and claimed the 1409 head was on the 220 cylinder.
Up until today, I thought it was all BS. I looked at a clean 2001 220 that had very little done to it - it even had the factory kickstand. Sure enough the cylinder was a 220, but the head had 1409 on it.
So for you 220 owners, do any of you have a 1409 head or are they the 1410's?
doctord23
Re: Question for 220 owners
Post by doctord23 »
My 220s are up at my cabin, so I can't look at the heads to answer your question directly, but I can tell you that the two motors take different heads. I once bought what was listed as a 220 head on ebay, but when I sent it to Ron Black, he told me that it was a 200 head. The obvious difference is the 6mm difference in diameter.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
s10gto
Post by s10gto »
1409 here on my 05 220.
cstuckless
Post by cstuckless »
Both my 220's are stamped 1409 on the head.
Colin
Sent from my GT-P3113 using Tapatalk
canamfan
Post by canamfan »
My 99 220 has 1409
s10gto
Post by s10gto »
Now you got me wondering what this 1410 is? I see it listed for the 220. Maybe Kawi was machining the same castings both ways for the 200 or 220 and the 1410 is a 220 cast replacment? :?
Tedh98
Post by Tedh98 »
Thanks guys for the replies.
Do any of you happen to be the original owners? I was thinking that maybe what is happening is that the owner at the time let the cast piston go too long and it took out the cylinder and head. They went on eBay and found the first and cheapest head they could find, which looks to be the 200.
I wish Ron could use the 200 head for a 220, because I have 3 of them. But I've been looking for months and can't find any 220's.
s10gto
Post by s10gto »
I bought my bike from the original owner with only 12 hours on it. Was in storage since 06. I did the top end and removed a factory piston and factory gaskets.
Tedh98
Post by Tedh98 »
s10gto wrote:I bought my bike from the original owner with only 12 hours on it. Was in storage since 06. I did the top end and removed a factory piston and factory gaskets.
Well that blows my theory.
pumpguy
Post by pumpguy »
Have no personal experience with a 220 head, but from what I've read, the 220 has a central spark plug tapping and the combustion chamber is concentric. The 200 head has an angled spark plug tapping and a non-concentric combustion chamber shape.
If the above is true, the central spark plug tapping and concentric combustion chamber shape on the 220 head makes re-machining easy. I've done heads with this arrangement using just a mandrel with spark plug threads chucked in the lathe. Just thread the head onto the mandrel and start cutting.
On the other hand, the 200's head would require a special fixture to mount in the lathe, and the irregular chamber shape makes it more complicated to get the desired chamber volume along with squish area shape and clearance.
pumpguy
Post by pumpguy »
After looking at some 200 heads, it looks like I'm wrong about the concentricity issue, but the angled spark plug tapping still makes machining more difficult.
C George
Post by C George »
doctord23 wrote:My 220s are up at my cabin, so I can't look at the heads to answer your question directly, but I can tell you that the two motors take different heads. I once bought what was listed as a 220 head on ebay, but when I sent it to Ron Black, he told me that it was a 200 head. The obvious difference is the 6mm difference in diameter.
3mm in diameter :)
The couple 200 heads I've seen ground out to work on 220's appear kind of crude.
Jim B
Post by Jim B »
Tedh98 wrote:So for you 220 owners, do any of you have a 1409 head or are they the 1410's?
The head on my '97 220 has a 1409 casting number. The spark plug is angled forward (the centerline of the plug is not perpendicular to the head gasket surface).
Socks with Sandals
Post by Socks with Sandals »
2003 220 with 1409 casting.
Tedh98
Post by Tedh98 »
I found another 220 on CL. Before driving to look at it I asked the seller what was stamped on the head - another 1409.
I think I'm going to email RB to see if he can clarify things.
Tedh98
Post by Tedh98 »
Jim B wrote:The head on my '97 220 has a 1409 casting number. The spark plug is angled forward (the centerline of the plug is not perpendicular to the head gasket surface).
My 200 heads have the spark plug angled forward as well.
Anyone care to guess the impact on performance of running a 200 head on a 220?
s10gto
Post by s10gto »
Without having both in front of me I would assume the 220 has a larger chamber so running a 200 head may create too high compression for pump fuel.
If I had both I could cc them to be sure.
I have been looking around and I can't find any kdx head with the 1410 markings?
C George
Post by C George »
It wouldn't work as the piston would hit the head as the squish area is 3mm smaller in diameter.
C George
Post by C George »
The 1409 seems to be the 220 head your looking for as my 05 / 220 with original head has that number
and the replacement 220 top end I purchased " don't know the year " has the same.
Tedh98
Post by Tedh98 »
C George wrote:The 1409 seems to be the 220 head your looking for as my 05 / 220 with original head has that number
That is what is confusing me as the fiche says the 1409 is the 200 head and the 1410 is the 220 head. It doesn't make sense that Kawasaki would use the same part number for both and force an employee to take a measurement to identify which is which.
I sent an email to RB and will update this thread when I hear back.
Thanks to all you 220 owners for checking what you have an replying.
