1993 KDX Clutch
icepick
1993 KDX Clutch
Post by icepick »
My son's 93 KDX clutch is giving us problems, the clutch is either engaged or it's not, there is no feathering of the clutch
any thoughts?
thanks
Re: 1993 KDX Clutch
Last oil change? You can try going to a different wt or ATF which may help, but if it's a 93 and hasn't had the clutch serviced you should open up the right side and inspect for proper clutch plate thicknesses, basket notching, cable adjustment. Has it always been that way or changed recently?
6 Riders
Re: 1993 KDX Clutch
Post by 6 Riders »
check the nut that holds the clutch to the bike.
scout_74134
Re: 1993 KDX Clutch
Post by scout_74134 »
Could the nut be too tight?
Gotanubike
1993 KDX Clutch
Post by Gotanubike »
You should also check that all the washers are there and in the correct spots. There's one behind the clutch basket with a sleeve on the input shaft(#92200, 92028) that is important for clutch function. And the one between the clutch pack and basket(also #92200)
1990 KDX200
