top end how to
actmobmar
top end how to
Post by actmobmar »
hi, i just bought an 01 kdx200, and want to pull the jug and check everything, is there a how to with torque specs on how to do the job? i am a mechanic by trade, so not fearful of doing the job, just primarily concerned about the kips. engine has 95 psi compression(per the previous owner, i will double check before dissassembly) thanks!
Has thanked: 15 times
Been thanked: 27 times
Re: top end how to
There are some threads here with a few pics and such, but no step by step with torque values and all. It would be a great idea to go ahead and pick up a service manual for your bike. Best money you'll ever spend aside from the initial purchase of your green machine. This is a good one. You can just purchase 1 year access for 19.99, and make sure you have it all printed out by the time your year is up.
http://www.cyclepedia.com/online-manual ... ice-guide/
Welcome to KDXRIDER!
actmobmar
top end how to
Post by actmobmar »
thanks for your help! i just checked the compression my self and it is around 140, which i happily assume is good!
Re: top end how to
Yessir, 140 is just fine. Never a bad idea to open up a new to you bike and check it out, though!
Keystone
Re: top end how to
Post by Keystone »
I'm mot a mechanic and tore the top end apart and rebuilt it by using the Kawasaki service manual and checking in on this site a few times about the KIPS. Cyclepedia did not impress me, more colorful photos than the service manual, but not much else.
ohgood
Re: top end how to
Post by ohgood »
actmobmar wrote:hi, i just bought an 01 kdx200, and want to pull the jug and check everything, is there a how to with torque specs on how to do the job? i am a mechanic by trade, so not fearful of doing the job, just primarily concerned about the kips. engine has 95 psi compression(per the previous owner, i will double check before dissassembly) thanks!
kips is easy... pull the pawl off first (it's nut is left hand thread) then the rest you'll understand once is in your hands...
see the left hand threaded but here:
koshari
Re: top end how to
Post by koshari »
I was gonna comment on the LH thread but ohGoods all over it.
ohgood
Re: top end how to
Post by ohgood »
koshari wrote:I was gonna comment on the LH thread but ohGoods all ovwr it.
please do anyway... all of this is new to me and I'm green green green... tend to miss things lately.
koshari
Re: top end how to
Post by koshari »
in other words conventionally turning the bolt counter clockwise to loosen will actually tighten this bolt.
Tioli
Country: Tasmania AUS
top end how to
Post by Tioli »
But hey don't forget to mention the suckernubi trap. If you don't pul the rubber boot halfway down and hold the shaft with a spanner its gonna bite you :doh:
Edit
Ok looks like my joke fell flat
What I ment if if you don't support the shaft while undoing it and you twist it either way there is a good chance you will end up breaking a little transfer leaver in the cases.
