As I'd really like a twin shock l had a few choices. A PE, a klx or an older kdx. Nether of the first 2 options suited me and as l dont want another non Australian kdx l thought a kdx 200 engine in a klx250 frame would be a good project.
The donor frame.
l placed an set of engine cases in the frame to see how it fitted and as you can imagine a little 200 engine in that 4 stroke frame gave plenty of room.
The first win was that I'm able to use the rear engine mount on the 200 motor with the swingarm bolt on the klx frame. There's a difference of 6mm in the width between the kdx engine and the klx spacer which looks to be an easy mod. I'll need to weld on the bottom engine mount to the frame, make the front mount plates and weld on something for the head stay to bolt to.
The sprockets look like they'll align fairly well too.
Cheers
Geoff
